メインコンテンツにスキップ
はじめに
Prereq to upper case guide—remove the I/O board after the logic board
パーツ
パーツは指定されていません。
  1. Remove the small rubber gasket from the corner of the upper case nearest the the I/O board. Remove the gasket from the corner nearest display cable connector. Remove the gasket from the corner nearest display cable connector.
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  2. If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector. If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  3. PCラップトップ用バッテリー
    An easy fix for a big power boost.
    ショップを見る
    PCラップトップ用バッテリー
    ショップを見る
  4. Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket. Be sure you are prying up on the retaining flap, not the socket itself. With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  5. Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket. De-route the cable from its notch in the logic board. De-route the cable from its notch in the logic board.
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  6. Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  7. Carefully lift the I/O board by its power cable and pull it away from the edge of the case. Carefully lift the I/O board by its power cable and pull it away from the edge of the case. Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
まとめ
Sam Goldheart
メンバー登録日: 2012年10月18日
381,873 ポイント
543のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
100 メンバー
9,030のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
