メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Air 11" Mid 2013 Battery Replacement
必要な工具と部品
    1. MacBook Air 11" Mid 2013 Battery Replacement, Lower Case: 手順 1、 1の画像 1
      この手順で使用する道具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Air 11" Mid 2013 Battery Replacement: 手順 2、 1の画像 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Air 11" Mid 2013 Battery Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 11" Mid 2013 Battery Replacement, Battery Connector: 手順 3、 2の画像 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Air 11" Mid 2013 Battery Replacement, Battery: 手順 4、 1の画像 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Air 11" Mid 2013 Battery Replacement: 手順 5、 1の画像 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
84 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
478,474 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
121 メンバー
72,713のガイドは作成済み
10件のガイドコメント
Reminder: Crimp the new battery’s ribbon cable before you screw it in so that you’ll have an easier time connecting it to the power terminal.
Andrew Harris - 返信 共有
That was too easy. After dealing with the glue and all the zif cables to replace the battery on a MacBook, this was just an easy breeze.
Steve Heffern - 返信 共有
Followed instructions, but MacAir lost gattery icon and will not charge replaced battery, despite SCO reboot and recheck on battery connector
russellseitz - 返信 共有
the battery I purchased has the battery connector in a different spot…it’s to the left…can it be slid over to the correct position?
Kirstie - 返信 共有
installed but now the macbook air trackpad ‘clicks’ when then touch it as if it’s slightly loose (it doesn’t physically do a click)
naquada - 返信 共有
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 82
過去 30 日: 332
今までの合計 61,366
