メインコンテンツにスキップ
MacBook Air 11インチ Mid 2012 ロジックボードの交換
必要な工具と部品
  1. MacBook Air 11インチ Mid 2012 ロジックボードの交換, 下部ケース: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $11.99
    購入する
    • まず、コンピューターをシャットダウンし、柔らかい素材の表面上に天面を下にして置きます。
    • 以下の10本のネジを外します:
    • 星型ペンタローブネジ 8mm 2本
    • 星型ペンタローブネジ 2.5mm 8本
    • 星型ペンタローブネジを外す際に必要な特別ドライバーはこちらで購入できます。
    When you say:
    Remove the following ten screws:
    Two 8 mm 5-point Pentalobe screws
    Eight 2.5 mm 5-point Pentalobe screws
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - 返信
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - 返信
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - 返信
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - 返信
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - 返信
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - 返信
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - 返信
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - 返信
  2. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 2、 1の画像 1
    • ディスプレイと下部ケースの間に指を入れ、下部ケースを引き上げて外します。
  3. MacBook Air 11インチ Mid 2012 ロジックボードの交換, バッテリー: 手順 3、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換, バッテリー: 手順 3、 2の画像 2
    • この手順では、作業中にパーツがショートしないように、バッテリーを取り外します。
    • スパッジャーの平面側先端を使用して、バッテリーコネクター両側の短辺を持ち上げて、ロジックボードのソケットから外します。
    • アクシデントでコネクタがソケットに接触しないように、バッテリケーブルをロジックボードから少し離して反対側に折り曲げます。
    My macbook air's configuration (Mid-2011 core i5) has a different battery connector. It slides into a receptacle on the logic board. If your battery connector does not look like the one pictured, use the pointy end of a spudger to depress the small indentation in the middle of the battery connector cable terminal, and pull aft to release the clasp mechanism.
    Ethan Cross - 返信
    Maybe your battery connector doesn't match the picture because these instructions are for the mid-2012 model and yours is mid-2011.
    colleenthompson - 返信
  4. MacBook Air 11インチ Mid 2012 ロジックボードの交換, SSD: 手順 4、 1の画像 1
    • SSDをロジックボードに固定している1つの2.9 mm T5トルクスネジを取り外します。
  5. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 5、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 5、 2の画像 2
    • 一方の手でSSDを掴み引き上げて、スパッジャーを使って差し込み、SSDの解放側を持ち上げます。
    • SSDを過剰に高くまで持ち上げないで下さい。
    • ドライブをソケットからまっすぐ引いてロジックボードから取り外します。
    • SSDを再装着する際は固定ネジを取り付ける前に、SSDが正しい位置に取り付けられているか確認してください。
    When you've completed all these steps to replace your SSD, don't despair if the MacBook Air shows a flashing folder with a question mark when you first power up the MacBook Air.
    - Power off the machine, then keep the option key (= Alt key) pressed down, power on the machine again, and keep the option key pressed down until a prompt appears.
    - If you've set a firmware password, then type it in at the prompt
    - You should now be prompted for a hard drive to boot from. Select "EFI Boot"
    - The MacBook Air should now boot to a window showing "OS X Utilities"
    - Click on the  at the top left, then select "Startup Disk..."
    - Select your SDD/Hard drive, and restart.
    Michael Welham - 返信
    When replacing the SSD, be careful about the connector orientation. Replacement boards look almost the same if they are upside-down. Note that the connector is not reversible - there is a notch that will only line up if the board is right-side up. If it doesn't seem to line up, flip the board over.
    shamino - 返信
    can i ask some links for some ssd’s that are compatible with that macbook model ?
    giannismistil - 返信
    Hi I completed steps above, but the MacBook Air 2012 doesn’t seem to read the drive, on reboot I get a flashing folder, and upon clicking Control R on reboot it goes to internet recovery mode and then can’t find the drive on disk utility. Any help would be much appreciated! Thanks, Devin
    Devin Patrick Hughes - 返信
    if you’re using an M2 adaptor, be mindful to check the compatibility with the other end. In my specific case my adaptor was only compatible with M2 Sata and not with M2 NVMe.
    Andres Urena - 返信
    This was a confusing upgrade. Sintech M.2 NGFF SSD fo 2010-2011 MacBook Air was used, yet it’s got a graphic in the sales content that claims it works with ‘M’ key only (NVMe, AHCI), so NOT SATA. Yet in the answered questions on Amazon the sales tech claims you MUST use SATA drive. I bought 2 NVMe SSD’s and found that the first USB adapter board was unstable with both. So, bought another adapter board that supported SATA and NVMe (RIITOP M.2 SSD to USB 3.1 adapter that claimed to be compatible with ‘M’ and ‘B+M’ SATA SSD’s) and a SATA SSD (Silicon Power A55 M.2 SATA III). The NVMe drives couldn’t be seen by the MacBook Air, but the SATA drive worked (Restore didn’t work, but SuperDuper! does fine). Physical install is as shown.
    Robert Sutherland - 返信
  6. MacBook Air 11インチ Mid 2012 ロジックボードの交換, I/O ボードケーブル: 手順 6、 1の画像 1
    • スパッジャーの平面側先端を使って、I/Oボード上のソケットからI/Oボードケーブルを持ち上げます。
  7. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 7、 1の画像 1
    • ファンに留められた接着剤からI/Oボードケーブルを剥がします。
    I did not peel the I/O board connector, it is not needed to be peeled away securing it to the fan.
    Leonard Francis - 返信
  8. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 8、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 8、 2の画像 2
    • スパッジャーの平面側先端を使用して、I/Oボードコネクタを持ち上げて、ロジックボードのソケットから取り外します。
    • コネクタをソケットから外すときは、コネクタをまっすぐ持ち上げてください。 ソケットはロジックボード上の非常に深いところにあり、コネクタの左右両側からこじ開けてしまうと、ロジックボードを損傷してしまうことがあります
    • I/Oボードケーブルを取り出します。
  9. MacBook Air 11インチ Mid 2012 ロジックボードの交換, ファン: 手順 9、 1の画像 1
    • スパッジャーの先端を使って、ファンケーブルZIFソケットの保持フラップを持ち上げます。
    • ソケット自体ではなく、ヒンジのある保持フラップを持ち上げているか確認してください。
    Das ging leider nicht wie beschrieben: an der Mutter links unten war eine Platine befestigt, die über den beschriebenen Sicherungsbügel ragt, so dass der nicht erreichbar war. Ohne zu wissen, ob diese Platine einfach abgeschraubt werden kann, habe ich das lieber gelassen.
    Lise Lotte - 返信
  10. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 10、 1の画像 1
    • ファンを天蓋に固定している下記の3つのネジを取り外します。
    • 2つの5.2 mm T5 トルクスネジ
    • 1つの3.6 mm T5 トルクスネジ
  11. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 11、 1の画像 1
    • 天蓋からファンを持ち上げて、ゆっくりとファンのリボンケーブルをソケットから引きながら、同時にファンを取り出します。
    The replacement fan's ribbon cable is a few mm longer than the original. I t will loop upwards a bit after mounting. The rubber lip on top of the old fan needs to be transferred to the new fan.
    Martin Heinrich - 返信
  12. MacBook Air 11インチ Mid 2012 ロジックボードの交換, バッテリー: 手順 12、 1の画像 1
    • バッテリーを上部ケースに固定している次の5本のネジを外します:
    • 5.2mm T5トルクスネジ 2本
    • 6mm T5トルクスネジ 1本
    • 2.6mm T5トルクスネジ 2本
  13. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 13、 1の画像 1
    • バッテリーを扱う際は、6つのリチウムポリマーセルに触れたり、絞らないでください。
    • バッテリーをロジックボードに最も近い端から持ち上げて、上部ケースから取り外します。
  14. MacBook Air 11インチ Mid 2012 ロジックボードの交換, ロジックボード: 手順 14、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換, ロジックボード: 手順 14、 2の画像 2
    • スパッジャーの平面側先端を使って、I/Oボードの電源ケーブルを上部ケースに固定している接着ループを外します。
    • ロジックボードのソケットから電源ケーブルを引き抜いて、I/Oボードを取り外します。
    • ケーブルをロジックボード表面と平行にして、Air本体前方の端に向けて引っ張ります。
  15. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 15、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 15、 2の画像 2
    • スパッジャーの先端を使って、キーボードバックライトリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。
    • ソケットからキーボードリボンケーブルを引き抜きます。
  16. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 16、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 16、 2の画像 2
    • スパッジャーの先端や指の爪を使って、トラックパッドリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • Airの前端に向けて、ソケットからトラックパッドリボンケーブルをまっすぐ引き抜きます。
  17. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 17、 1の画像 1
    • スパッジャーの先端を使って、ロジックボードの切り込まれたスロットより右側スピーカーのケーブルを取り出します。
  18. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 18、 1の画像 1
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットから右側スピーカーケーブルコネクタを持ち上げて外します。
    • ケーブルの下から持ち上げてください。
  19. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 19、 3の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 19、 3の画像 2 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 19、 3の画像 3
    • ディスプレイデータケーブルのロックに付いている黒いプラスチックのフラップの下に、スパッジャーの先端を慎重に差し込んで、ロックをソケットから上向きに出します。
    • ディスプレイデータケーブル付近の上部ケースの角から小さなゴム製ガスケットを取り外します。
  20. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 20、 1の画像 1
    • ソケットからロックを離しながら、ディスプレイデータケーブルをソケットから慎重に引き抜きます。
    • ディスプレイデータケーブルを外す際に上向きに引っ張ると、ソケットがロジックボードにダメージを与えてしまう可能性があります。ご注意ください。
  21. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 21、 2の画像 1 MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 21、 2の画像 2
    • スパッジャーの平面側先端を使って、両方のアンテナケーブルコネクタをAirport /Bluetoothカードのソケットから持ち上げて取り外します。
    I'm having difficulty getting the antenna connectors to snap back on. Any suggestions?
    Rusty Walters - 返信
  22. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 22、 1の画像 1
    • ロジックボード上の切り欠きからアンテナケーブルを慎重に通して外します。
  23. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 23、 1の画像 1
    • ロジックボードを上部ケースに固定している3.6mm T5トルクスネジを3本外します。
  24. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 24、 1の画像 1
    • 壊れやすいヒートシンクと絡まりやすいケーブルに注意しながら、ロジックボードアセンブリを慎重に持ち上げて、上部ケースから取り外します。
  25. MacBook Air 11インチ Mid 2012 ロジックボードの交換, ロジックボード: 手順 25、 1の画像 1
    • AirPort/Bluetoothカードをロジックボードに固定している2.9mm T5トルクスネジを1本外します。
  26. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 26、 1の画像 1
    • AirMac / Bluetoothボードの外れた側の先端を少し持ち上げ、ロジックボードのソケットから引き抜きます。
    • ロジックボード上のソケットの損傷を防ぐため、AirMac / Bluetoothカードの外れた側の先端を過度に持ち上げないでください。
    • AirMac / Bluetoothボードをロジックボードから取り出します。
  27. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 27、 1の画像 1
    • ヒートシンクをロジックボードに固定している2.5mm T5トルクスネジを4本外します。
  28. MacBook Air 11インチ Mid 2012 ロジックボードの交換: 手順 28、 1の画像 1
    • 4本のネジをすべて取り外した後、ヒートシンクがロジックボードに貼り付いている場合は、スパッジャーを使ってヒートシンクをCPUおよびGPUの表面から慎重に外します。
    • ロジックボードからヒートシンクを取り出します。
    • ロジックボードが残ります。
    • ヒートシンクを再び取り付けるときは、必ず放熱グリスを新しく塗布してください。 これまで一度も塗布したことがない方向けの使用ガイドがあります。
    awesome, you've virtually saved my macbook air from costly repairing fees. Long live the spirit of DIY ...
    Avatar Ng - 返信
    Be careful if you are running High Sierra and have converted your SSD to the new file system. I replaced my logic board after updating to High Sierra and converting my SSD. The new board would not recognize the drive. I restored the system from a Sierra backup image and all is fine. My assumption is that the High SIerra update includes firmware changes to support the new file system.
    David - 返信
    I changed the logic board but now the battery doesn't load anymore - it's a new battery and worked! Checked everything twice. Any ideas?
    Susan K - 返信
終わりに
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
26 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
6人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,810 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
2 件のコメント
Just for your information, this guide is not for the A1465 because the motherboard they are showing is from an A1370. The touchpad and touchpad flex cable are different in both models.
lap tech - 返信
I concur this does not match the A1465 board in some areas. The Airport / Bluetooth connectors are in a different spot and the heatsink is different. Perhaps some photos from another board were used in a few places. The rest appears to be the same, so far.
Digital Oxygen Photography - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 73
今までの合計 26,656
