メインコンテンツにスキップ
MacBook Air 11" Mid 2012 I/O Board Cable Replacement
必要な工具と部品
  1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: 手順 3、 2の画像 1 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: 手順 3、 2の画像 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: 手順 4、 2の画像 1 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: 手順 4、 2の画像 2
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: 手順 5、 2の画像 1 MacBook Air 11" Mid 2012 I/O Board Cable Replacement: 手順 5、 2の画像 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
503,085 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
コメント 1 件
You only show the basic part of the removal. You do not show how to actually remove that board. You should have shown more steps.
Steven Pierce - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 2,850
