はじめに
Use this guide to replace the bare logic board on your MacBook Air. Before reinstalling the heat sink, be sure to apply a new layer of thermal paste.
必要な工具と部品
この手順で使用する道具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
23 の人々がこのガイドを完成させました。
7 件のコメント
Just so you guys know I could successfully reaplace the A1370 Core2Duo Late 2010 board for a A1370 i7 Mid 2011 board. you are going to need the heatsink and battery from the newer model as well. the problem I am facing right now is the wifi/bluetooth antenna been too short for the new position of the airport card. as soon as I get a chance I'll try to re route the cables and try to fix it.
Igorfeghali, another question: why do you need the battery too?
kautame -
Hello everybody,
I made it too: I replaced my 2GB RAM C2D-logic board in my native 11” 2011 MBA for a 2nd-hand “ i5 1,6 GHz / 4GB RAM” logic board. The same here: you will need a 2011 battery (the connector of the 2010 battery is too far left for the connector of the 2011 logic board). My logic board luckily came w/ native fan and heatsink, so my only challenge will now be to get BT and WIFI antenna cable long enough to fit the new place of the bt/wifi-card.
@igorfeghali, and others: How did you manage this problem? Any idea for an adapter-cable? Any suggestions, anybody?
Thank you, alle the best,
Chris
Chris -
