メインコンテンツにスキップ
MacBook Air 11" Early 2015 I/O Board Replacement
必要な工具と部品
  1. MacBook Air 11" Early 2015 I/O Board Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: 手順 3、 2の画像 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: 手順 4、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: 手順 4、 2の画像 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 5、 1の画像 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2015 I/O Board Replacement, Fan: 手順 6、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement, Fan: 手順 6、 2の画像 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 7、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 7、 2の画像 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 8、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 8、 2の画像 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 9、 1の画像 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 10、 3の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 10、 3の画像 2 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 10、 3の画像 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2015 I/O Board Replacement, Battery: 手順 11、 1の画像 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 12、 1の画像 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: 手順 13、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: 手順 13、 2の画像 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 14、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 14、 2の画像 2
    この手順で使用する道具:
    購入する
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 15、 3の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 15、 3の画像 2 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 15、 3の画像 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 16、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 16、 2の画像 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 17、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 17、 2の画像 2
    • De-route the cable from its notch in the I/O board.
  18. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 18、 2の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 18、 2の画像 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 19、 1の画像 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  20. MacBook Air 11" Early 2015 I/O Board Replacement: 手順 20、 3の画像 1 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 20、 3の画像 2 MacBook Air 11" Early 2015 I/O Board Replacement: 手順 20、 3の画像 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
終わりに
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,936 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,277のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 50
今までの合計 6,514
