はじめに
This guide will show you how to replace the logic board.
必要な工具と部品
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
Use the flat end of a spudger to pry the power button cable connector up off the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board and set it aside.
12 の人々がこのガイドを完成させました。
2件のガイドコメント
¿Alguien sabe como diagnosticar que el problema es la tarjeta madre? El led interno 601 está siempre prendido pero el led602 parpadea dos veces cuando le aprieto el botón de encendido. Y bueno, no prende la mac.
alancordia - 返信
i got the same problem …You have fixed?
