はじめに
Replace your IR board to regain control of your mini via an Apple remote.
パーツ
パーツは指定されていません。
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Use the tip of a spudger to remove the black electrical tape spanning the interconnect board and optical drive.
Remove the single Phillips screw securing the IR board to the internal frame.
2 の人々がこのガイドを完成させました。
