この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove the top housing to access your mini's internals.
必要な工具と部品
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
47 の人々がこのガイドを完成させました。
2 件のコメント
Does this work to remove a disc
ajunelady6 - 返信
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
