メインコンテンツにスキップ
Mac mini Model A1176 Top Housing Replacement
必要な工具と部品
  1. Mac mini Model A1176 Top Housing Replacement, Top Housing: 手順 1、 2の画像 1 Mac mini Model A1176 Top Housing Replacement, Top Housing: 手順 1、 2の画像 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini Model A1176 Top Housing Replacement: 手順 2、 3の画像 1 Mac mini Model A1176 Top Housing Replacement: 手順 2、 3の画像 2 Mac mini Model A1176 Top Housing Replacement: 手順 2、 3の画像 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini Model A1176 Top Housing Replacement: 手順 3、 2の画像 1 Mac mini Model A1176 Top Housing Replacement: 手順 3、 2の画像 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 Top Housing Replacement: 手順 4、 2の画像 1 Mac mini Model A1176 Top Housing Replacement: 手順 4、 2の画像 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 Top Housing Replacement: 手順 5、 2の画像 1 Mac mini Model A1176 Top Housing Replacement: 手順 5、 2の画像 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 Top Housing Replacement: 手順 6、 2の画像 1 Mac mini Model A1176 Top Housing Replacement: 手順 6、 2の画像 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
終わりに
50 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Walter Galan
706,151 ポイント
1,203のガイドは作成済み
2件のガイドコメント
Does this work to remove a disc
ajunelady6 - 返信
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 93
今までの合計 31,803
