この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove the internal frame to access most of your mini's internals.
必要な工具と部品
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
もう少しです!
終わりに
