Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
First remove the AirPort antenna (the larger of the two), located near the power button.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
Lift the audio board ribbon cable up out of its socket.
If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
I’ve managed to replace the built-in AirPort card in my Mac Mini with a different card. I bought a Broadcom BCM94321MC (which is natively found in Santa Rosa/Penryn Macs) and I installed it successfully into the Mac. Mac OS X picked it up immediately and I noticed a modest increase in speed compared to the previous AirPort card. My guess is that the single antenna in the Mac Mini is the bottleneck for WiFi speeds. Since it looks like the Mac Mini uses mini PCI-E for its AirPort card, I suppose any mini PCI-E WiFi card can work, assuming that it is compatible with Mac OS X and fits the longer size required by the Mac.
