はじめに
Prerequisite only.
必要な工具と部品
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
この手順で使用する道具:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
もう少しです!
ゴール
ある他の人がこのガイドを完成しました。
