はじめに
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
必要な工具と部品
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
もう少しです!
ゴール
9 の人々がこのガイドを完成させました。
