はじめに
Use this guide to strip and replace the outer case of your Mac mini Late 2014.
必要な工具と部品
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
この手順で使用する道具:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
3 の人々がこのガイドを完成させました。
