はじめに
Use this guide to replace a noisy or worn-out fan.
必要な工具と部品
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
31 の人々がこのガイドを完成させました。
3 件のコメント
If you shouls happen to rip the connector off the logic board, just replace the end of the connector wire with a usb plug and the connect it to the computer, Vola
