メインコンテンツにスキップ
Mac mini (PowerPC) Lower Case Replacement
必要な工具と部品
  1. Mac mini (PowerPC) Lower Case Replacement, Top Housing: 手順 1、 2の画像 1 Mac mini (PowerPC) Lower Case Replacement, Top Housing: 手順 1、 2の画像 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini (PowerPC) Lower Case Replacement: 手順 2、 3の画像 1 Mac mini (PowerPC) Lower Case Replacement: 手順 2、 3の画像 2 Mac mini (PowerPC) Lower Case Replacement: 手順 2、 3の画像 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini (PowerPC) Lower Case Replacement: 手順 3、 2の画像 1 Mac mini (PowerPC) Lower Case Replacement: 手順 3、 2の画像 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini (PowerPC) Lower Case Replacement: 手順 4、 2の画像 1 Mac mini (PowerPC) Lower Case Replacement: 手順 4、 2の画像 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini (PowerPC) Lower Case Replacement: 手順 5、 2の画像 1 Mac mini (PowerPC) Lower Case Replacement: 手順 5、 2の画像 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini (PowerPC) Lower Case Replacement: 手順 6、 2の画像 1 Mac mini (PowerPC) Lower Case Replacement: 手順 6、 2の画像 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini (PowerPC) Lower Case Replacement, Mass Storage Unit: 手順 7、 1の画像 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  8. Mac mini (PowerPC) Lower Case Replacement: 手順 8、 1の画像 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  9. Mac mini (PowerPC) Lower Case Replacement: 手順 9、 1の画像 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  10. Mac mini (PowerPC) Lower Case Replacement: 手順 10、 1の画像 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  11. Mac mini (PowerPC) Lower Case Replacement: 手順 11、 1の画像 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  12. Mac mini (PowerPC) Lower Case Replacement, Lower Case: 手順 12、 1の画像 1
    • The cables you're about to remove are very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
    • Disconnect the power button and sleep light cables from the logic board.
  13. Mac mini (PowerPC) Lower Case Replacement: 手順 13、 1の画像 1
    • Remove the single black Phillips screw from the front left corner of the logic board.
  14. Mac mini (PowerPC) Lower Case Replacement: 手順 14、 1の画像 1
    • Use one hand to slide a spudger underneath the logic board and the other to pull back on the black sleep light unit. Lift up the with the spudger to free the logic board from the lower case and use both hands to slide the logic board toward you.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
635のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 8,839
