はじめに
Restore sound to your machine by replacing the speaker.
  1. Power down your Mac mini, disconnect all of the cables, and flip it over. Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Once you have the first side free, rotate the Mac mini and start prying up on the front edge. Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Keep working around the perimeter, freeing the clips along the final edge. Keep working around the perimeter, freeing the clips along the final edge.
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Flip the Mac mini back over and lift the top housing off of the lower housing. Flip the Mac mini back over and lift the top housing off of the lower housing.
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. If your mini does not have Airport installed, then skip this step.
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  8. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  9. Remove the yellow tape securing the power button cable to the black plastic framework.
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  10. Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  11. Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  12. If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  13. Remove the three long, black Phillips screws from the corners of the fan. These screws are strongly threaded, and will offer significant resistance.
    • Remove the three long, black Phillips screws from the corners of the fan. These screws are strongly threaded, and will offer significant resistance.
    • There is no screw in the bottom left corner.
  14. Lift the fan out of the computer.
    • Lift the fan out of the computer.
  15. Peel up the yellow tape securing the speaker and fan cables to the bottom of the hard drive.
    • Peel up the yellow tape securing the speaker and fan cables to the bottom of the hard drive.
  16. Use a #1 Phillips to remove the two screws attaching the right side of the hard drive to the plastic framework. You'll need to angle the screwdriver down to get access to the lower right screw. Be sure to apply steady force to the screws and turn slowly so as not to strip them.
    • Use a #1 Phillips to remove the two screws attaching the right side of the hard drive to the plastic framework. You'll need to angle the screwdriver down to get access to the lower right screw. Be sure to apply steady force to the screws and turn slowly so as not to strip them.
  17. Use the same screwdriver and steady force to remove the two screws attaching the left side of the hard drive to the plastic framework.
    • Use the same screwdriver and steady force to remove the two screws attaching the left side of the hard drive to the plastic framework.
  18. Use a spudger to pry the hard drive away from the interface board. Wedge the flat end of the spudger between the interface board and the far right side of hard drive and wiggle back and forth until the hard drive slides out about a sixteenth of an inch. Then move to the other side and repeat the procedure. Go back and forth until the hard drive slides free.
    • Use a spudger to pry the hard drive away from the interface board. Wedge the flat end of the spudger between the interface board and the far right side of hard drive and wiggle back and forth until the hard drive slides out about a sixteenth of an inch. Then move to the other side and repeat the procedure. Go back and forth until the hard drive slides free.
    • When reinstalling the hard drive, make sure that you don't slide the top pins into the lower row of holes.
  19. Lift the hard drive out of the assembly.
    • Lift the hard drive out of the assembly.
  20. While holding the assembly with the speaker resting on the table, remove the four black Phillips screws holding the speaker in place and their associated rubber bumpers.
    • While holding the assembly with the speaker resting on the table, remove the four black Phillips screws holding the speaker in place and their associated rubber bumpers.
    • When replacing the speaker, place the rubber bumpers into the plastic casing first, then slide the screws into them, and finally line up the speaker with the screws. When working on the lower screws, you'll need to angle the end of the screw up a bit, as the speaker sits higher on the framework than you might expect.
  21. Deroute the speaker cable from the plastic framework, removing tape as necessary.
    • Deroute the speaker cable from the plastic framework, removing tape as necessary.
  22. The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
    • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
    • Disconnect the speaker connector from the interface board.
    • Pull the speaker out from the plastic framework.
まとめ
2 の人々がこのガイドを完成させました。
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
623のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 4,819
