はじめに
Use this guide to replace the power supply in your Mac Pro Late 2013.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
必要な工具と部品
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
Jim WIlson - 返信
Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
D300 = 2GB each card. Very few apps uses two cards at the same time.
Gio Cas -
The (5) Screws are Apple part number 923-0713
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
On my machine, a TR7 worked to remove them due to the weird angle.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
Ended up being T9 screws for me.
T8 screws for me, i did and edit to this step
Ended up being T15 screws on my machine
Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
Need to add T9 Torx Screwdriver to list of tools at the beginning of this article.
Remove the four 9.0 mm silver T10 Torx screws from the sides of the power supply.
25 の人々がこのガイドを完成させました。
7 件のコメント
it works!
thanks much!
How do I purchase the Power Supply Module?
boinkboink - 返信
how did you make out? i just took my old PSU out, I was testing myself because I didn’t think I could actually take it apart!!! anyway, now I need to buy a new one. any suggestions?
Hi, please where can I buy the PSU ?
Where can I get this smps.. any lead please
