はじめに
Use this guide to replace the power supply in your Mac Pro Late 2013.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
ツール
パーツ
パーツは必要ありません。
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
7 の人々がこのガイドを完成させました。
