メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Prereq only.
パーツ
パーツは指定されていません。
  1. Flip the Mac Pro back over and set it gently on a flat surface.
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  2. Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side). Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
  3. Remove the power supply cage from the top of the power supply.
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  4. Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  5. Remove the power supply assembly from the Mac Pro.
    • Remove the power supply assembly from the Mac Pro.
終わりに
Andrew Optimus Goldheart
メンバー登録日: 2009年10月17日
469,049 ポイント
410のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
135 メンバー
15,092のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 56
