はじめに
The interconnect board hosts connections to the logic board, IO board, and both GPUs. Use this guide to remove and replace the interconnect board.
必要な工具と部品
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
Jim WIlson - 返信
Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
D300 = 2GB each card. Very few apps uses two cards at the same time.
Gio Cas -
The (5) Screws are Apple part number 923-0713
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
On my machine, a TR7 worked to remove them due to the weird angle.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
Ended up being T9 screws for me.
T8 screws for me, i did and edit to this step
Ended up being T15 screws on my machine
7 の人々がこのガイドを完成させました。
4 件のコメント
Why is it necessary to remove the fan?
