メインコンテンツにスキップ
Mac Pro Late 2013 Interconnect Board Replacement
必要な工具と部品
  1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: 手順 1、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: 手順 1、 2の画像 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Interconnect Board Replacement: 手順 2、 3の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 2、 3の画像 2 Mac Pro Late 2013 Interconnect Board Replacement: 手順 2、 3の画像 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: 手順 3、 3の画像 1 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: 手順 3、 3の画像 2 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: 手順 3、 3の画像 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 Interconnect Board Replacement: 手順 4、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 4、 2の画像 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Interconnect Board Replacement: 手順 5、 1の画像 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 Interconnect Board Replacement: 手順 6、 1の画像 1
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Interconnect Board Replacement: 手順 7、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 7、 2の画像 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Interconnect Board Replacement: 手順 8、 1の画像 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: 手順 9、 3の画像 1 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: 手順 9、 3の画像 2 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: 手順 9、 3の画像 3
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Interconnect Board Replacement: 手順 10、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 10、 2の画像 2
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: 手順 11、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: 手順 11、 2の画像 2
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Interconnect Board Replacement: 手順 12、 3の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 12、 3の画像 2 Mac Pro Late 2013 Interconnect Board Replacement: 手順 12、 3の画像 3
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Interconnect Board Replacement: 手順 13、 1の画像 1
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
  14. Mac Pro Late 2013 Interconnect Board Replacement: 手順 14、 3の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 14、 3の画像 2 Mac Pro Late 2013 Interconnect Board Replacement: 手順 14、 3の画像 3
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Interconnect Board Replacement: 手順 15、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 15、 2の画像 2
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Interconnect Board Replacement: 手順 16、 2の画像 1 Mac Pro Late 2013 Interconnect Board Replacement: 手順 16、 2の画像 2
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,810 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
4 件のコメント
Why is it necessary to remove the fan?
johnsburdett - 返信
Hola necesito comprar esta placa de interconexión, donde puedo encontrarla? Saludos
RailabMac - 返信
excellent, thank you very much, I wanted to ask you where I can get this plate, what is the reference?
Asdrubal - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 46
今までの合計 5,475
