メインコンテンツにスキップ
Mac Pro First Generation Hard Disk Drive (HDD) Replacement
必要な工具と部品
  1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Case Panel: 手順 1、 1の画像 1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Locate the Hard Drive Bays: 手順 3、 1の画像 1
    • Locate the desired hard drive bay after opening the case .
    • This is usually the drive closest to the front of the case.
  4. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 手順 4、 3の画像 1 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 手順 4、 3の画像 2 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 手順 4、 3の画像 3
    • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
    • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
  5. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 手順 5、 3の画像 1 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 手順 5、 3の画像 2 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 手順 5、 3の画像 3
    • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
    • Locate the four 6-32 type screws on the Hard Drive sled.
    • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Charlie Franklin
メンバー登録日: 10/12/14
1,148 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G24
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 30
過去 30 日: 189
今までの合計 22,046
