はじめに
Replacing the hard drive is straight forward and all you need is a Phillips head screw driver. Use this guide to replace a hard drive in your Mac Pro.
IMPORTANT
Make sure you back up your files onto the replacement hard drive before swapping in the machine. If switching to a brand new hard drive you will probably have to re install your operating system in order to keep your computer running as usual.
Also be careful with your hard drive as damaging it can mean that you lose your files.
必要な工具と部品
Locate the desired hard drive bay after opening the case .
This is usually the drive closest to the front of the case.
Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
Locate the four 6-32 type screws on the Hard Drive sled.
Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
10 の人々がこのガイドを完成させました。
