メインコンテンツにスキップ
Mac Mini Mid 2011 Hard Drive Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Mac Mini Mid 2011 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  2. Mac Mini Mid 2011 Hard Drive Replacement: 手順 2、 1の画像 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • This connector can be very fragile—lift gently and evenly.
  3. Mac Mini Mid 2011 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  4. Mac Mini Mid 2011 Hard Drive Replacement: 手順 4、 3の画像 1 Mac Mini Mid 2011 Hard Drive Replacement: 手順 4、 3の画像 2 Mac Mini Mid 2011 Hard Drive Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    Mac mini Logic Board Removal Tool
    購入する
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  5. Mac Mini Mid 2011 Hard Drive Replacement: 手順 5、 1の画像 1
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
    • Only pull the logic board assembly out of the outer case until the edge of the I/O board is about .5" away from the edge of the aluminum outer case.
  6. Mac Mini Mid 2011 Hard Drive Replacement: 手順 6、 2の画像 1 Mac Mini Mid 2011 Hard Drive Replacement: 手順 6、 2の画像 2
    • Pull the hard drive away from the front edge of the mini and remove it from the outer case.
ゴール
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,509
