メインコンテンツにスキップ
Mac mini Late 2014のハードドライブアセンブリの交換
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Mac mini Late 2014のハードドライブアセンブリの交換, ハードドライブアセンブリ: 手順 1、 2の画像 1 Mac mini Late 2014のハードドライブアセンブリの交換, ハードドライブアセンブリ: 手順 1、 2の画像 2
    • ハードドライブをドライブトレイに固定している6.5mmT8ネジを計4本(両側に2本ずつ)外します。
    Like others, a T8 screw driver worked best for me on the 4 hard drive screws.
    sorinjc - 返信
    it is t8 not t9. you owe me a TR6 Torx Security bit :D
    giammin - 返信
    I found the 4 screws quite hard to remove and needed to use an 8mm spanner on the back of my T8 screwdriver to get them loose.
    Reiner Friedel - 返信
    Screws have loctite residue. I put a tiny drop of fresh blue (semi-permanent) on each screw before reinstalling.
    Jon Scott - 返信
    T9 was the right one for mine
    Bill Pennock - 返信
    T9 Torx from recommended barely allowed me to remove these screws. I had to press very strong them into screws, so that pressure and minimal adhesion made it possible to move something.
    Vitalijs Ozornins - 返信
    T8 was more appropriate for me !!!
    afajner - 返信
    The instructions at the top recommend a T9 but the link plops a TR9 into your basket. In any event, the T8 works better.
    tom - 返信
    T8 was also good for me. Mini was manufactured in 2016 October.
    soul.tan - 返信
    TR7 did the job.
    Benni Piron - 返信
    Is this a security screwdriver just like the TR6 Security Screwdriver?
    Shubham Ojha - 返信
    When i did the re-assembly as I was adding a drive to a pcie only mac, i didnt have any t8 screws (so used standard phllips onces which came with the sata kit but i struggled to make sure the wires were out of the way. I dont know if the configuration for mac minis with drive is slightly different but you need to be careful not to screw down any of the wires (i think for IR sensors).
    Edward Chandler - 返信
    Can anyone confirm a T8S (security) driver is needed for this, not a non-security T8?
    Cornfritter - 返信
  2. Mac mini Late 2014のハードドライブアセンブリの交換: 手順 2、 3の画像 1 Mac mini Late 2014のハードドライブアセンブリの交換: 手順 2、 3の画像 2 Mac mini Late 2014のハードドライブアセンブリの交換: 手順 2、 3の画像 3
    • ハードドライブをドライブトレイから持ち上げて外します。
    • 再組み立ての際にはハードドライブケーブルをドライブトレイの穴に通すことに気をつけてください。
終わりに
再組み立ての際には手順の逆を行なってください。
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,602 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,718のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,861
