メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Prerequisite only
パーツ
パーツは指定されていません。
  1. Remove the two 12 mm T6 screws from the fan.
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw.
  2. The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved. Do not attempt to remove the fan entirely. Lift the fan straight up to free the captive screw from its hole in the logic board.
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  3. Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board. Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  4. Remove the fan from the Mac mini.
    • Remove the fan from the Mac mini.
終わりに
Sam Goldheart
メンバー登録日: 2012年10月18日
436,444 ポイント
547のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
133 メンバー
15,614のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 186
