メインコンテンツにスキップ
MSI VR601 WiFi card Replacement
必要な工具と部品
  1. MSI VR601 WiFi card Replacement, Open the back cover: 手順 1、 2の画像 1 MSI VR601 WiFi card Replacement, Open the back cover: 手順 1、 2の画像 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 手順 2、 2の画像 1 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 手順 2、 2の画像 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: 手順 3、 1の画像 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
終わりに
作成者
1人の作成者と共同作成されました。
Geir Ove Andersen
メンバー登録日: 06/06/22
7,815 ポイント
5のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,516のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 235
