はじめに
This guide will show you how to replace the Wi-Fi card in a MSI MS-1782 laptop. If you are having trouble connecting to the Wi-Fi after exhausting all software fixes, use this guide to replace the Wi-Fi card. There are also steps you should do before the disassembly, like unplugging the battery.
必要な工具と部品
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
