はじめに
This troubleshooting guide will give step-by-step instructions on how to replace the M.2 SSD on your MSI GT62VR 6RD Dominator laptop. This troubleshooting guide has no special requirements or potential hazards. It is recommended to replace your SSD if you experience a few of the following: data corruption, slow read/write speeds, bad sector errors. Little to no risk of injury is involved to complete these guide steps and is not time consuming to complete.
必要な工具と部品
Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
ある他の人がこのガイドを完成しました。
コメント 1 件
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
