はじめに
If your MSI GS66 Stealth laptop (model 11UE-007) is having problems with the overall cooling system and it is not the cooling fan, the thermal paste might need to be replaced.
Thermal paste is used to transfer heat away from the CPU and the cooling system. Loss of effectiveness from this part can result in the laptop heating up to dangerous levels that put other components of the laptop at risk.
This part can dry up over time and will need replacement at some point. This guide has the necessary steps to fully replace the thermal paste and return the laptop to peak efficiency.
必要な工具と部品
Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
2 の人々がこのガイドを完成させました。
11件のガイドコメント
If you only have issues with thermals on your cpu then I would just replace the gray thermal paste directly on the cpu. The “pink stuff” is also thermal paste for the other components. It would normally have thermal pads but there must not have been enough room for them in the design.
Hi, do you need to disconnect the battery before doing this. As I have tried and mine is not coming out no matter what. Thanks
It’s not necessary to disconnect the battery. It’s just best practice to. Is the connector not coming out or the battery itself?
The connector itself will not come out even with what I’d consider excessive force. I am looking to clean my fans and repaste. Are there any other precautions I should take if I were to remove the cooler without disconnecting the battery? Thanks.
