メインコンテンツにスキップ
MSI GS63VR 7RF Stealth Pro Battery Replacement
必要な工具と部品
  1. MSI GS63VR 7RF Stealth Pro Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
    • Once the back plate is loose, close the screen for an easier time properly removing it.
  2. MSI GS63VR 7RF Stealth Pro Battery Replacement: 手順 2、 1の画像 1
    • Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
    • After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go.
    • Another method for keeping track of all the screws would be to secure each removed screw near the hole that it was removed from with a piece of painters or masking tape. This type of tape is easy to remove from the fuzzy surface but strong enough to secure the screw to the back cover.
  3. MSI GS63VR 7RF Stealth Pro Battery Replacement: 手順 3、 3の画像 1 MSI GS63VR 7RF Stealth Pro Battery Replacement: 手順 3、 3の画像 2 MSI GS63VR 7RF Stealth Pro Battery Replacement: 手順 3、 3の画像 3
    • Locate the battery.
    • Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device.
    • Gently pull and wiggle the multiple colored wired connector out from the socket.
    • If you are removing the original battery, the back has a couple foam strips that were installed for cushioning. Those can be carefully removed and placed on the new replacement battery, but it is not necessary.
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chris Gifford
メンバー登録日: 10/20/17
980 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G1, Julie Fall 2017 UMass Dartmouth, Team S2-G1, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S2G1
3 メンバー
5のガイドは作成済み
コメント 1 件
Please note, everyone that is replacing. Please replace this with this type of battery model: BTY-M6J. Or else your battery may get damage.
Alexander Eap - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 80
今までの合計 23,307
