メインコンテンツにスキップ
MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement
必要な工具と部品
  1. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 2、 1の画像 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 3、 2の画像 1 MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 3、 2の画像 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement, Battery: 手順 4、 1の画像 1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 5、 1の画像 1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 6、 2の画像 1 MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 6、 2の画像 2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement, MotherBoard: 手順 7、 1の画像 1
    • Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
    • Disconnect the wires connecting to the motherboard to the USB ports.
    • Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
  8. MSI GS60 Ghost Pro 4K Gold Edition Motherboard Replacement: 手順 8、 1の画像 1
    • Lift the motherboard up and out of the device casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
nonEdward666
メンバー登録日: 10/18/17
340 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G2, Julie Fall 2017 UMass Dartmouth, Team S2-G2, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S2G2
4 メンバー
7のガイドは作成済み
2 件のコメント
How to proceed with a keyboard replacement?
Had a water spill, some keys not working anymore, could this be fixable by a keyboard swap?
Can this be a n IC damage?
Fahad Hassan - 返信
Same question :
How to replace this keyboard ?
c dric - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 774
