はじめに
This replacement guide is difficult only because in order to replace the RAM, the motherboard need to be taken out of the device completely. However, replacing the RAM itself is not hard at all. so basically all the hard work is to unplug the motherboard completely and take it out to reach the RAM.
必要な工具と部品
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
3 の人々がこのガイドを完成させました。
コメント 1 件
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
