はじめに
If your MSI GP62MVR 6RF Leopard Pro is emitting no sound after multiple reboots, setting adjustments, and updates, then the speakers themselves are most likely the issue. Whether there is a disconnect between the speaker’s wires and the motherboard or the speakers are broken, you will need to open the bottom cover of your device and replace or reconnect the speakers. For this task, you will need a Philips #0 screwdriver, a jimmy tool, and a pair of latex gloves. No special skills are required. Although the latex gloves are not required, we recommend them to avert the hazard of electrical shock or the leaving of residue on sensitive electrical components on the motherboard.
必要な工具と部品
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
