メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Looking for a guide to help you replace your MSI GP60 2PE Leopard hard drive? This is the guide for you. Simply follow a few steps and your hard drive will be out in no time.
  1. Flip MSI GP60 2PE Leopard, so that the back is facing up.
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. Find the unlock tab located on the upper right side of the device, then slide it to the right.
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. Slide and hold the release tab on the left side of the battery, so that you can remove the battery. Slide and hold the release tab on the left side of the battery, so that you can remove the battery. Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. While holding the release tab, remove the battery slowly. While holding the release tab, remove the battery slowly. While holding the release tab, remove the battery slowly.
    • While holding the release tab, remove the battery slowly.
  5. Flip the device over so the back is facing up.
    • Flip the device over so the back is facing up.
  6. Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver. There is a screw located under the battery; lift the battery up to access it.
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. Once all four screws are removed, lift the back off. Once all four screws are removed, lift the back off.
    • Once all four screws are removed, lift the back off.
  8. Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
    • Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
  9. Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier. Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier. Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
    • Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
終わりに
2 の人々がこのガイドを完成させました。
Zoey Calcagno
メンバー登録日: 2018年10月04日
636 ポイント
5のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G4, Karnes Fall 2018 Linn Benton Community College, Team S1-G4, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 745
