メインコンテンツにスキップ
MSI GE72 6QF Apache Pro RAM Replacement
必要な工具と部品
  1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: 手順 1、 2の画像 1 MSI GE72 6QF Apache Pro RAM Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro RAM Replacement: 手順 2、 1の画像 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro RAM Replacement: 手順 3、 1の画像 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro RAM Replacement: 手順 4、 2の画像 1 MSI GE72 6QF Apache Pro RAM Replacement: 手順 4、 2の画像 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro RAM Replacement: 手順 5、 2の画像 1 MSI GE72 6QF Apache Pro RAM Replacement: 手順 5、 2の画像 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro RAM Replacement: 手順 6、 2の画像 1 MSI GE72 6QF Apache Pro RAM Replacement: 手順 6、 2の画像 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro RAM Replacement, RAM: 手順 7、 2の画像 1 MSI GE72 6QF Apache Pro RAM Replacement, RAM: 手順 7、 2の画像 2
    • When you open the back cover, the RAM will be located as shown in the picture.
  8. MSI GE72 6QF Apache Pro RAM Replacement: 手順 8、 3の画像 1 MSI GE72 6QF Apache Pro RAM Replacement: 手順 8、 3の画像 2 MSI GE72 6QF Apache Pro RAM Replacement: 手順 8、 3の画像 3
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  9. MSI GE72 6QF Apache Pro RAM Replacement: 手順 9、 3の画像 1 MSI GE72 6QF Apache Pro RAM Replacement: 手順 9、 3の画像 2 MSI GE72 6QF Apache Pro RAM Replacement: 手順 9、 3の画像 3
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tanmay Kumar
メンバー登録日: 04/17/17
461 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S14G4
4 メンバー
8のガイドは作成済み
1件のガイドコメント
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 28
今までの合計 5,125
