はじめに
This guide will show you how to replace the fans in your MSI GE72 6QF Apache Pro.
必要な工具と部品
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Slide the optical drive out of the laptop.
Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
Or send me and email rauff191@gmail.com
Fully remove the fans from the rest of the laptop.
what is the thing that the fans are held in called like that big metal thing i need to get that replaced i think and i dont know how ot search for it
Using a Phillips #00 screwdriver, remove the six 5mm screws.
Separate the fans from the silver fan covers.
Should be mentioned that doing this will ALSO require repasting the CPU/GPU!!!
Not doing this step will result in improper cooling more than likely. - CRITICAL STEP
Thanks for the heads up
20 の人々がこのガイドを完成させました。
9 件のコメント
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Where can I buy new fans?
Where do you buy the replacement fans
customgirl - 返信
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
You need both fans cpu and gpu here is a link https://www.amazon.com/Cooling-Ge72-Ge62...
Hello, nice work. I have problem with my msi ge72 6qd and i wander if is possible to find better fan from stock. Any ideas? Thank you again nice work and you are very understandable.
Great article! I didn't even have any screws left over when I finished! :)
Google Sux - 返信
