メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MSI GE72 6QF Apache Pro Fan Replacement
必要な工具と部品
  1. MSI GE72 6QF Apache Pro Fan Replacement, Battery: 手順 1、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Fan Replacement: 手順 2、 1の画像 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Fan Replacement: 手順 3、 1の画像 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Fan Replacement: 手順 4、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 4、 2の画像 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Fan Replacement: 手順 5、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 5、 2の画像 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Fan Replacement: 手順 6、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 6、 2の画像 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Fan Replacement, Fan: 手順 7、 3の画像 1 MSI GE72 6QF Apache Pro Fan Replacement, Fan: 手順 7、 3の画像 2 MSI GE72 6QF Apache Pro Fan Replacement, Fan: 手順 7、 3の画像 3
    • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
    • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
    • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
  8. MSI GE72 6QF Apache Pro Fan Replacement: 手順 8、 3の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 8、 3の画像 2 MSI GE72 6QF Apache Pro Fan Replacement: 手順 8、 3の画像 3
    • Unplug both of the fan power cords from the laptop using a spudger.
  9. MSI GE72 6QF Apache Pro Fan Replacement: 手順 9、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 9、 2の画像 2
    • Continue to use the spudger to carefully separate the wires of the power cord from the laptop.
  10. MSI GE72 6QF Apache Pro Fan Replacement: 手順 10、 2の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 10、 2の画像 2
    • Fully remove the fans from the rest of the laptop.
  11. MSI GE72 6QF Apache Pro Fan Replacement: 手順 11、 3の画像 1 MSI GE72 6QF Apache Pro Fan Replacement: 手順 11、 3の画像 2 MSI GE72 6QF Apache Pro Fan Replacement: 手順 11、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the six 5mm screws.
    • Separate the fans from the silver fan covers.
終わりに
20 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tanmay Kumar
メンバー登録日: 04/17/17
461 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S14G4
4 メンバー
8のガイドは作成済み
9件のガイドコメント
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Aaron Carlston - 返信 共有
Where can I buy new fans?
Aschwin Versteegden - 返信 共有
Where do you buy the replacement fans
customgirl - 返信 共有
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
dylan davis - 返信 共有
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
dylan davis - 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 42
過去 30 日: 132
今までの合計 26,428
