はじめに
MNT Reform has two identical battery boards. Each board has four 18650 cells with LiFePO4 chemistry (3.2V). Only use LiFePO4 cells with MNT Reform! Other chemistries, like Li-Ion or NiMH are incompatible.
必要な工具と部品
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Unplug the battery pack cables from the BATLEFT and BATRIGHT sockets on the motherboard.
Remove the following screws securing the left battery board to the main box:
Four M2×4 pan head Philips screws
Remove the following screws securing the right battery board to the main box:
If you are installing new boards, unplug the battery cables from your old boards.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
ある他の人がこのガイドを完成しました。
