必要な工具と部品
To turn on the Bill Break function, go to RT config and check the box marked bill break.
To configure the Bill Break click on the Bill Break Config button.
Once you’re in there you’ll have three options. Add, Edit, and Delete. If you select delete it will get rid of an acceptable denomination.
Add will bring up a screen where you can select a new denomination that the machine will break and how it’s given to you once it is broken.
In order to select Edit you will have to select one of the already existing denominations. After you’ve done so and you click Edit it will allow you to change how the denomination is broken.
