メインコンテンツにスキップ
M3D Micro Data and Power Port Replacement
必要な工具と部品
  1. M3D Micro Data and Power Port Replacement, Data and Power Ports: 手順 1、 3の画像 1 M3D Micro Data and Power Port Replacement, Data and Power Ports: 手順 1、 3の画像 2 M3D Micro Data and Power Port Replacement, Data and Power Ports: 手順 1、 3の画像 3
    • Place pressure on the central print bed and simultaneously pull up on the outer perimeter of the 3D printer. The cube shaped enclosure will lift up.
  2. M3D Micro Data and Power Port Replacement: 手順 2、 3の画像 1 M3D Micro Data and Power Port Replacement: 手順 2、 3の画像 2 M3D Micro Data and Power Port Replacement: 手順 2、 3の画像 3
    • Remove the print bed cover and locate the four screws holding the print bed to the base of the unit. Remove the four 9.5 mm screws using the 3.5 Hex head from the bit kit.
  3. M3D Micro Data and Power Port Replacement: 手順 3、 2の画像 1 M3D Micro Data and Power Port Replacement: 手順 3、 2の画像 2
    • Lifting the print bed reveals the motherboard that controls the unit. This is the hardware that allows the printer to connect to the computer. The port on the left is the data and the port on the right is the power input.
  4. M3D Micro Data and Power Port Replacement: 手順 4、 3の画像 1 M3D Micro Data and Power Port Replacement: 手順 4、 3の画像 2 M3D Micro Data and Power Port Replacement: 手順 4、 3の画像 3
    • The ports are primarily soldered on to the board but are additionally secured using glue. Use the sharp metal spudger tool to gently pry apart the glue surrounding the ports.
  5. M3D Micro Data and Power Port Replacement: 手順 5、 2の画像 1 M3D Micro Data and Power Port Replacement: 手順 5、 2の画像 2
    • To remove the charging port grasp the port with a pair of pliers and use a soldering iron to desolder the joints at the red marks while carefully pulling away with the pliers.
  6. M3D Micro Data and Power Port Replacement: 手順 6、 2の画像 1 M3D Micro Data and Power Port Replacement: 手順 6、 2の画像 2
    • To replace the power port, match the four contact points on the board to the new port and carefully solder the components together.
  7. M3D Micro Data and Power Port Replacement: 手順 7、 2の画像 1 M3D Micro Data and Power Port Replacement: 手順 7、 2の画像 2
    • To replace the USB data port, follow the same procedure as Step 5. The contact pins for the data port are on the back. The red marker indicates the four contact pins that must be matched up and carefully soldered on.
終わりに
作成者
4人の作成者と共同で作成されました。
Ilian D
メンバー登録日: 09/28/17
125 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017人のメンバー
USFT-NANCE-F17S3G2
4 メンバー
10のガイドは作成済み
2 件のコメント
Between the 2nd & 3rd images in step 1, the print head has vanished without explanation.
How do we remove the print head so we can remove the top half of the case to be able to proceed to step 2?
That’s the only piece if data missing.
Otherwise, it seems to be a great article.
Thank you.
Justin Hamilton - 返信
I found this document to replace the Z-Belt. It includes the steps to remove the print head.
https://micro.printm3d.com/technical-sup...
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 22
今までの合計 1,819
