メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector. In the process of this removal, it will be demonstrated how to clean the area of any dust and how to recycle the waste material- old light bulb.
パーツ
パーツは指定されていません。
  1. Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Unscrew the bulb screws on either side of the silver plate.
    • Unscrew the bulb screws on either side of the silver plate.
  4. Remove the light bulb from the projector by lifting the silver handle and pulling up.
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Use a new Q-tip to clean the fan blades and hole in which the light enters.
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Dispose of the bulb by sending it to a recycling center.
    • Dispose of the bulb by sending it to a recycling center.
終わりに
ある他の人がこのガイドを完成しました。
Desiree Benitez
メンバー登録日: 2017年01月21日
128 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017人のメンバー
USFSM-STEWART-S17S1G1
19 メンバー
16のガイドは作成済み
コメント1件
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 532
