メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will show how to lubricate the power dial. Your power dial will operate smooth after completing this guide.
  1. Unplug the device before proceeding. Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
  2. Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
    • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
    • Remove the cord from the phone base.
  3. Use finger to remove the battery cover. Use finger to remove the battery cover.
    • Use finger to remove the battery cover.
  4. Remove the Volume Dial by gently grasping the dial and pulling away from the base. Remove the Volume Dial by gently grasping the dial and pulling away from the base.
    • Remove the Volume Dial by gently grasping the dial and pulling away from the base.
  5. Remove the 6 screws from the base shell.
    • Remove the 6 screws from the base shell.
    • Remove the 3 12mm screws with the Philips head #1 screw driver.
    • Remove the 3 18mm screws with the Philips head #1 screw driver.
  6. Pry off the base shell using a Plastic Opener Tool. Pry off the base shell using a Plastic Opener Tool.
    • Pry off the base shell using a Plastic Opener Tool.
  7. Inside base shell on circuit board, lubricate power switch.
    • Inside base shell on circuit board, lubricate power switch.
    • CAUTION: Make sure lubricant does not circuit board. This can damage the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
Norberto Sanchez
メンバー登録日: 2012年09月26日
70 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G59
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 718
