メインコンテンツにスキップ
Lorex MC6950 Camera Lens Replacement
必要な工具と部品
  1. Lorex MC6950 Camera Lens Replacement, Camera Lens: 手順 1、 2の画像 1 Lorex MC6950 Camera Lens Replacement, Camera Lens: 手順 1、 2の画像 2
    • To remove a bad lens, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
  2. Lorex MC6950 Camera Lens Replacement: 手順 2、 2の画像 1 Lorex MC6950 Camera Lens Replacement: 手順 2、 2の画像 2
    • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
    • Once the camera is removed, remove the wires from the outer containment shell.
    • Be careful. The metal spudger could damage the camera if not handled with care.
  3. Lorex MC6950 Camera Lens Replacement: 手順 3、 2の画像 1 Lorex MC6950 Camera Lens Replacement: 手順 3、 2の画像 2
    • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
    • The wires attaching the circuit board to the shell should be removed as well.
  4. Lorex MC6950 Camera Lens Replacement: 手順 4、 1の画像 1
    • Now the motor housing must be removed from the circuit board first as it is in the way of the screws associated with the lens. There are three 5mm JIS 0 screws located on the lens side of the circuit board to remove the motor.
  5. Lorex MC6950 Camera Lens Replacement: 手順 5、 1の画像 1
    • The lens has two 5 mm JIS 0 screws located under the motor's previous location. Once these are removed, the lens can be replaced.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Elijah Conlin
メンバー登録日: 11/07/17
379 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S2-G2, Harley Fall 2017 IUPUI, Team S2-G2, Harley Fall 2017人のメンバー
IUPUI-HARLEY-F17S2G2
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 798
