メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw. Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out. Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  4. Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it. Carefully remove the back panel
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
まとめ
Alex Kusmierz
メンバー登録日: 2016年09月26日
601 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G1
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 48
