メインコンテンツにスキップ
Lorex A-MPX IR Bullet Camera Disassembly
必要な工具と部品
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: 手順 1、 2の画像 1 Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: 手順 1、 2の画像 2
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: 手順 2、 2の画像 1 Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: 手順 2、 2の画像 2
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 手順 3、 3の画像 1 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 手順 3、 3の画像 2 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 手順 3、 3の画像 3
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 手順 4、 3の画像 1 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 手順 4、 3の画像 2 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 手順 4、 3の画像 3
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: 手順 5、 1の画像 1
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
終わりに
作成者
2人の作成者と共同で作成されました。
Hans
メンバー登録日: 10/20/14
1,920 ポイント
6のガイドは作成済み
チーム
Mero IT Services Mero IT Services人のメンバー
Business
1 メンバー
6のガイドは作成済み
3 件のコメント
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - 返信
Can you do a disassembly video on Lorex C861MB camera ?
Mark Curry - 返信
How much is this camera
Michael Teeter - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 30
今までの合計 2,514
