はじめに
Disassemble your Logitech VX Nano Wireless Mouse to either replace your broken scroll wheel or clean your current one.
必要な工具と部品
Pull down on the battery release tab to remove the battery cover.
Remove battery cover.
Use a Phillips #1 screwdriver to remove the two 6 mm-long screws at the bottom of the battery compartment.
この手順で使用する道具:Tweezers$4.99
Use the flat end of a spudger to carefully pry one side of the scroll wheel out of its clear plastic housing.
Use a set of tweezers to grasp either side of the scroll wheel near the axle. Use one side of the tweezers to keep the scroll wheel from popping back into the clear plastic housing on the side you already disconnected.
At the same time, use the other side of the tweezers to pull the opposite side of the scroll wheel loose from the clear plastic housing.
4 の人々がこのガイドを完成させました。
2件のガイドコメント
Thanks for the instruction!
Although I think it is impossible to remove the skates (pads, feet, whatever you call them) without damaging them.
But the replacement is still relatively easy to find on Ali or ebay.
You’re totally right! I’ll add this clarification to the step. Thanks!
