はじめに
This a guide designed to assist you in removing and replacing both speakers present in your Logitech UE Megaboom speaker.
必要な工具と部品
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Insert a opening tool between the grating and the body of the speaker
Pry up allowing the tabs to pop out of place.
Apply the same procedure to the grating covering the second speaker.
7 の人々がこのガイドを完成させました。
7 件のコメント
Thank you! I was able to glue one of the passive radiators back in place.
Where can I find a speaker replacement? Thanks for your time
I’ve got the same issue. Where can i find the speaker replacement?
For those looking for replacement speakers - either directly from Logitech ( $$$ ) or find a broken one on eBay that’s been water logged or some such thing and recover the speakers from that (since they are waterproof speakers)
Thanks for the article - turns out one of my speaker grills had popped loose and was imitating a blown speaker!
yes! same issue!
i bought a replacement speaker (which i still have if anyone is looking), but it was a speaker grill stopper that had come unglued and vibrated - sounding exactly as if a blown speaker or radiator.
